Thread: Cable run in attic
04-13-2010, 12:10 PM #1
Cable run in attic
Any violation running cabling through insulation other than unprofessional?
How about through the ceiling? I did not notice anything on the other side, there must have been a chase below.
04-13-2010, 04:34 PM #2
Re: Cable run in attic
No problem with running the NM cables through the insulation, but a big problem with the insulation being installed downside up (upside down ) and the paper facing being left exposed.
04-13-2010, 07:55 PM #3
Should we worry about that paper shoved up against the pipe? Is that a B-vent?
04-13-2010, 08:02 PM #4
04-14-2010, 10:58 AM #5
It is a b vent and not in good shape. It was just a little loose.
Check out the picture looking up.
