Results 1 to 3 of 3
    Paul Bousquet's Avatar
    Paul Bousquet Guest
    Default ungrouded GFCI test
    I have an older home with a mix of grounded and ungrounded outlets. In the bathroom, there is an ungrounded outlet with a GFCI receptacle. Should it trip with a GFCI outlet tester? it does trip with the test button and resets ok
    Regards
    Default Re: ungrouded GFCI test
    "I have an older home with a mix of grounded and ungrounded outlets. In the bathroom, there is an ungrounded outlet with a GFCI receptacle. Should it trip with a GFCI outlet tester? it does trip with the test button and resets ok "
    An ungrounded GFCI will trip with the built in test button, but not with the test button of a plugin tester.
    It's supposed to have a little sticker on it that says "No Equipment Ground", for what that's worth.
