Results 1 to 20 of 20
    Sep 2009
    McAllen, Texas
    Default Found Answer.... Arc Circuit requirements for Texas
    Do we have to put as a deficiency a house that is not completely protected by arc circuit or only one that does not have them in the bedrooms. Please reply
    As per Texas Administrative Code and TREC Standards of Practice...
    Must report...
    the lack of arc-fault circuit interrupting devices serving family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreations rooms, closets, hallways, or similar rooms or areas; and
    failure of operation of installed arc-fault circuit interrupter devices.
    Richard Flores
    Professional Inspector TREC # 8139
    www.premier-rgv.com
    Default Re: Found Answer.... Arc Circuit requirements for Texas
    Quote Originally Posted by Richard Flores View Post
    Must report...
    Gosh almighty that is an absurd and stupid requirement! You just can't add AFCI's to an older electrical system.
    Default Re: Arc Circuit requirements for Texas
    Richard,
    The answer to your question is "YES".
    The answer is right there in your TREC Standards of Practices. If your not writing it up as such, you'd be in violation.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Virtually every residential property you inspect will be noted as "Deficient" in both sections of the electrical (Service Entrance ... AFCIs and Branch Circuits ... GFCIs). There are few (if any) homes ... including new construction ... that meet the current requirements.
    That being said since February 2009 with the new TREC SOP you have been required to make such a comment of being "Deficient" for both. Fundamentally (even though we are not code inspectors) it is based on the current NEC-2008.
    If you are not and you happen to get audited by TREC Legal you could be fined or at least have your hand's slapped for not following the SOP.
    There are many more such items in the SOP that you had best make sure you are aware of ... not just in electrical.
    Nolan Kienitz Guest
    Richard,
    I noted your sample report is the 7A-0 template. I'm hoping that you are using the current 7-2 template otherwise you are in another bad situation of not using the current required report template.
    Chicago
    Quote Originally Posted by Nolan Kienitz View Post
    Hello Nolan,
    So, the HI is required to report the lack of AFCI as a deficiency. Is the owner of the property required to correct the defect?
    Just curious.
    Sincerely,
    Corey
    Quote Originally Posted by Corey Friedman View Post
    Hello Nolan,
    Just curious.
    Sincerely,
    Corey
    I'm not Nolan, but no nothing that a home inspector reports on is in any way a requirement for correction.
    The HI is regulated in Texas, not the home buyer or seller.
    imported_John Smith's Avatar
    imported_John Smith Guest
    Nolan,
    It looks to me like you can use REI 7A-1 still. Or am I missing something. You are correct if he is using 7A-0 he would be in violation. I hate to say it, but I wasnt even aware there was a form REI 7-2 until I read your post.
    Why are two reports acceptable now?
    RULE ยง535.223 Standard Inspection Report Form
    The Texas Real Estate Commission adopts by reference Property Inspection Report Form REI 7A-1, approved by the Commission in 2008, and Property Inspection Report Form REI 7-2, approved by the Commission in 2009, for use in reporting inspection results. These documents are published by and available from the Texas Real Estate Commission, P.O. Box 12188, Austin, Texas 78711-2188.
    I went to TREC and looked up the history of the forms. Says some typograhical error in regards to check boxes. I know my spell check goes nuts on the disclaimer wording.
    When does the "grace" period end for REI 7A-1.
    Nolan Kienitz Guest
    TREC has not set a firm date for the retirement of the 7A-1. In my last e-mail from a TREC legal-eagle it was noted there was a slip-up in setting the retirement date of 7A-1 last fall.
    It will likely be addressed yet sometime this year.
    In the meantime both the 7A-1 and 7-2 are permitted.
    I would use 7-2 and get ready for probably yet another version from what I've heard. No details, but likely.
    Nolan Kienitz Guest
    Corey,
    Jim L. is correct. TREC HIs can call things deficient all day long and no one is "required" to make any changes.
    All depends upon how bad the seller wants to sell the home.
    I guess it's true what say.... "Everything is bigger in Texas" - even the rules
    You folks pulling for regulation of HI, be careful what you wish for, you just might get it. The only state's legislation I have heard of that is more onerous is the one that prohibits citing code and defective electric panels. Other than that I am afraid that we have more rules and less protection for HI than anyplace I have heard of.
    Nolan Kienitz Guest
    And it is likely going to get worse from the rumblings I keep hearing out of Austin.
    Also ... if a pending lawsuit (Seller suing HI for 'doing his job') actually gets resolution by June/July this year we will have a whole new can of worms to deal with.
    Been floating through the legal system since late last summer and is supposedly due to be completed by June/July. I've not had a current update, but about a month ago it was still alive.
    I thought TREC was only being schmoozed by the Realtors and Insurance companies. I guess we can add report writing software companies to the suitors.
    Nolan Kienitz Guest
    IJS - None of them are schmoozing TREC. TREC is a PIA when it comes to providing clarification of what they precisely want or will allow in the templates.
    Drives the software folks nuts in trying to get answers.
    I know from personal experience as I help a couple of them debug their platforms and templates to try and ensure they meet the TREC rules.
    "taint easy ... I can assure you.
    Heron Longoria Jr.'s Avatar
    Heron Longoria Jr. Guest
    Rick,
    The State of Texas has adopted the 2008 edition of the N.E.C.
    The Electricians are licensed thru the Texas Dept. of Licensing and Regulation, which makes all electricians wire to the State Code.
    Which means= Arc-Fault breakers ahould be in all locations specified as well as in the bedrooms...
    Heron L.
    Quote Originally Posted by Heron Longoria Jr. View Post
    Rick,
    Heron L.
    That would be in new homes I hope..... Or do you know of a method of installing AFCI breakers when the home was never wired for them?
    You are right Scott,
    The "existing" installations are excempt. Unless--...you do a complete re-wire, then you would have to comply with current Code.
    Sep 2009
    McAllen, Texas
    Richard,
    Thanks for the reminder Nolan... I have had that sample report for years. I have been using the new template since TREC has requested it..
    I just updated my sample report because I don't want Imported John Smith to be concerned over my status..
    Richard
    Heron,
    Good to see you on the board.. How are the courses going?
    Richard Flores
    www.premier-rgv.com
