Results 1 to 3 of 3
    Tim Moreira's Avatar
    Tim Moreira Guest
    Default From the old board, Circuit Breaker Short Circuit Fault Rating
    How many of you HI's check the short circuit fault rating of the breakers in a panel? Does the rating equal or exceed the fault current in the area the property located?
    Byron Lentz's Avatar
    Byron Lentz Guest
    Default Re: From the old board, Circuit Breaker Short Circuit Fault Rating
    Why would you ever check that?
    Tim Moreira Guest
    I wouldn't. Not my original post.
    This is from the old board.
    I believe this was from Dick Whitfield. Not sure.
