Results 1 to 3 of 3
Thread: Recessed Luminare Above Shower
06-01-2010, 04:25 PM #1
Does a low voltage (12VAC) recessed luminaire installed above the shower/ bathtub require GFCI protection?
06-01-2010, 06:39 PM #2
06-02-2010, 04:20 AM #3
Re: Recessed Luminare Above Shower
Thanks for the replies.
I replaced the 120V recessed can above my shower with a 12V 50 watt recessed can. I hooked up the primary leads (120V) of the transformer to the existing switched wires which get its power from the load side of a GFCI outlet. It works fine but I was just curious if it was a code requirement.
