Results 1 to 10 of 10
Thread: Doubles thea are singles
06-07-2010, 07:26 PM #1
This is the craziest thing I've seen in a long time. Why would anyone do this!! Every breaker is tied to the one next to it???????
06-07-2010, 07:48 PM #2
Re: Doubles thea are singles
Can't answer why. Those are not approved handle ties tho.
06-07-2010, 08:00 PM #3
"Could be" ... multiwire circuits? Or 240 volt circuits? Or ... ?
Regardless, though, as Jim said "Those are not approved handle ties tho."
06-07-2010, 08:04 PM #4
Thanks, forgot to say it's in a 1999 1701sqft log cabin.
06-07-2010, 10:46 PM #5
06-08-2010, 05:20 AM #6
Now that I didn't think of... lol
06-08-2010, 09:55 PM #7
06-09-2010, 04:32 PM #8
Nominally that's true, but in practice voltage fluctuates all over the place depending on numerous factors. One power conditioner I installed has voltage meters that record minimum and maximum voltage over a 24hr period. I regularly saw minimums under 210V and maximums over 260V on the nominal "240V" service. Hence the power conditioner...
(RMS voltage was typically around 230V under normal demand.)
06-09-2010, 04:51 PM #9
In my area in NC the power company is allowed 10% either way so if the exact voltage advertised is 240 volts......216 to 264 is acceptable to the power company if you have a voltage complaint.....so if you say any number between 216 and 264 you will be correct.
06-09-2010, 05:41 PM #10
"so if you say any number between 216 and 264 you will be correct"
Incorrect.
The specified voltage is what the variation is allowed to be around, i.e., 120 volts / 240 volts.
If one happened to measure the voltage as 117.3 volts / 234.6 volts, one would look like an idiot referring to that as "117.3 volts / 234.6 volts". The voltage would be 120 volts / 240 volts, or simply 120/240 volts.
