Results 1 to 11 of 11
    Default what is this thing?
    This is at the front entrance of a 12 year old Toll Bros house. Never seen one before.
    Jun 2008
    Default Re: what is this thing?
    Maybe a sensor pickup to allow the utility company to remotely read the meter?
    Kary Krismer's Avatar
    Kary Krismer Guest
    I would guess an alarm switch, assuming it's roughly waist high.
    Or maybe a motion sensor?
    "When properly adjusted, the IR sensor will operate even when sunlight is directly shining into it."
    Thanks, Micheal. Do they make a lens for garage door sensors as well?
    Thanks!
    Ft. Myers, FL
    Wow John, 12 years old, thats like brand new to you isnt it....
    Paul Kondzich
    Ft. Myers, FL.
    Utah
    Looks like a mini-flat screen TV turned sideways with an aluminum frame to me.
    But then I can be a smart a$$ sometimes.
    Philip's Avatar
    Philip Guest
    Isn't that a self destruct button in case the house goes into foreclosure.
    You would think they would put it in a more secure spot.
    Of course it is a sensor, but what is it turning on and off
    Kary Krismer Guest
    I've seen those inside. We recently had clients buy a house where almost every room had them for AV equipment remotes.
    I'm not sure what you would have that would be IR based outside the house though. That would seem a bit odd.
    Dec 2007
    Holladay, UT
    Can anyone tell me why you would need this outside?
    http://acloserlookslc.com/
