    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Distribution Panel
    Does this ground have to be isolated on a separate lug or does this look acceptable? This is at the distribution panel.
    Thanks,
    Ryan
    Aug 2008
    Default Re: Distribution Panel
    Are you asking about the AL conductor?
    Ryan Stouffer Guest
    No the aluminum ground. it is in the middle of the copper grounds. behind the neutral.
    Quote Originally Posted by Ryan Stouffer View Post
    I think you are both referring to the same conductor???
    If so, that would be okay as I am sure that terminal bar is rated for either copper and aluminum (I did not say rated for "both" as that might indicate to some that "both" could be in the same terminal).
    If all the white painted conductors are grounds and not white neutrals, they would all be allowed in that terminal bar.
