Results 1 to 2 of 2
    Stephen Clausen's Avatar
    Stephen Clausen Guest
    Default 1975 Bryant panel ground bar
    This Bryant panel has common and ground bars that are connected as a unit. Common and ground wires are mixed together. Is this okay? I am not an electrician. I just want to be safe.
    Aug 2008
    Default Re: 1975 Bryant panel ground bar
    Is this service equipment or another panel? Are you asking about both a ground and a neutral in the same buss hole?
    Regardless of panel type the neutrals need to be one per hole. Grounds can typically be doubled up in certain size ranges.
