Thread: Panel wire corrosion
08-02-2010, 05:16 AM #1
Saw this recently in a previously flooded basement. All the copper wire in the panel is corroded. Ductwork especially corroded too. All the drywall had been removed & hauled away, but does not sound like Chinese drywall issue anyway. Symptoms of that should be blackened wiring. Located in Noth East Maryland. Built in 1995.
Help on the cause of this corrosion would be greatly appreciated.
08-02-2010, 05:26 AM #2
Re: Panel wire corrosion
08-02-2010, 06:10 AM #3
Nick;
A very wet/humid environment is the likely,simple answer. It's just that I have never seen so much corrosion in a panel that is otherwise fine.
08-02-2010, 07:21 AM #4
Water.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
