Results 1 to 2 of 2
    Jul 2010
    NC
    Default Aluminum wire in panel
    Found aluminum wiring at neutral bus bar in panel today, and with the rats nest of wiring it made it difficult to locate which breakers were serviced by this wire. It looked like copper at most of the breaker terminals. What course of action would you advise?
    Default Re: Aluminum wire in panel
    You were there but I would suspect that those red wire nuts have copper and aluminum wire to pigtail to the breaker. Of course that is wrong. I would advise giving out the CPSC aluminum wire info brochure and calling it out for a competent electrician to do repairs.
