Thread: Microwave ovens test
09-13-2010, 08:51 AM #1
How long do you test Microwave ovens for ? I alway just heated a peace of wet paper and called it good... But the other day I had one that had so many button and settings on it the only one I could get the thing to work on was the potato setting L.O.L. Any ways the I Let the thing run for a few and sparks/smoke started going off inside...
So I'm now going run all these things for a bit longer...
Best
Ron
09-13-2010, 09:02 AM #2
Re: Microwave ovens test
I don't believe that their is any way to consistently test a microwave. There are so many different wattage levels out there. Then you have convection combo units to add to the mix.
I don't ever report them as being tested.
I have often thought of bringing along a hot pocket so that I can state:
Cooked one standard hot pocket in time indicated on package with no visible problems plus I would have a good reason to eat lunch
09-13-2010, 10:36 AM #3
In Texas, we're required to operate the micowave. It is suggested that you heat a container of water or other heating method.
09-13-2010, 12:24 PM #4
In North Carolina, we are required to "inspect and operate" permanently installed microwave ovens.
I splash some water in a glass and hit 1 min button. If the temperature rises, then it is has been operated.
09-13-2010, 01:02 PM #5
I do the wet paper towel thing also. I turn it on for about 15 sec, look for a steaming paper towel and all is good. I also have one of those fandangled plastic bars with 3 red led lights. Most of the time I can't find it in my tool bag or I forget about it. The wet towel does the trick for me.
I know of one inspector that pops a bag of popcorn when he has clients with him. He has been doing it for years and has only had a couple of homeowners who became upset with the popcorn odor in the home after they left.
As for all of the buttons, etc. that are found on microwaves; It is my theory that all of the microwave makers only produce 50 units per model and then they make a new model! I seldom see the same microwave twice! Tell your clients that it worked on X setting and that was the only one you tried!
09-13-2010, 01:16 PM #6
I carry a small plastic tumbler in my tool bag. That way I can test the refrig's water dispenser hook up and fire up the microwave afterward.
09-13-2010, 02:17 PM #7
I through my hand towel in and let it cook for 10-15 sec. If it comes out warm, its good to go! I have left it too long while checking other things in the kitchen and scorched it, bad smell.
I tried to do a lazy mans smoores for the grandkids by placing a marshmallow and chocolate between two gram crackers on a small plate. The arcs and sparks flew! Tried it several times with different plates and the same results.... I was a microwave radio relay tech in the service, and can't give you a reason that a marshmallow arcs and sparks. Now I build a fire in the chimnea when the kids are in.
09-13-2010, 07:04 PM #8
