    Knoxville, TN
    Default Not what it appears
    Inspection today I found one of those multi outlet adapters plugged in. I tested it and found reverse polarity. For some reason I decided to unplug it to get to the "real" outlet. It tested correct for ground. The owners had another one plugged into the other kitchen outlet and I tested it and had the same results.
    I'm guessing cheap imported crap that had the wiring reversed.
    Default Re: Not what it appears
    That seems odd. By chance did you check it with a two lead wiggy?
    Art Dotson's Avatar
    Art Dotson Guest
    OOOOOOOOOOOO! Not cool! Did you notice if the device was UL listed?
    South-West Michigan
    Post Re: Not what it appears
    Good catch, Jack! When I bring stuff like that up with local inspectors, I get told I am "over-inspecting"!
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Hi, ALL &
    Yep - found something very similar this week --> a power bar permanently plugged-into a properly wired outlet (pre-checked) & my Tester read "ungrounded" at the far end, so could only be that device [either loose connection @ the ground, inside, or improperly manufactured]...
    CHEERS !
    -Glenn Duxbury, CHI
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    OK...the device is defective, but are we talking about reversed polarity or ungrounded (poor connection)? Both conditions were mentioned. Which was it...talking about the OP.
    I find reverse hot and neutral on the kitchen range outlet sometimes, it's not rare. Hecho en ?Mexico?
    Those adapters are property of the sellers I think. The only time I test them is if I can't reach the receptacle on the wall. Now you've got me wondering how many reversed outlets have been corrected by faulty adapters?
