Results 1 to 10 of 10
    Mar 2009
    Charlottesville, Va.
    Default Is this a carbon monoxide detector
    Yesterday I inspected a 5300 sq. ft. house with assorted security system devices and other atypical components, for my market anyway.
    Not that carbon monoxide detectors are atypical but I don't see them very often and couldn't readily confirm that indeed the white device in the photo was a carbon monoxide detector and not something else associated with the security system.
    Can someone please confirm that this is a carbon monoxide detector?
    Thanks.
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Is this a carbon monoxide detector
    It looks like a smoke or heat detector to me. About all you can do is take it down and get the model # if the label does not identify it's purpose.
    Nov 2009
    St Paul, MN
    If either were a carbon monoxide detector they would say so on the cover of the unit.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Jul 2010
    Kansas City Missouri
    The lower one appears to be a smoke or heat sensor that is tied into an alarm system.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Don Burbach's Avatar
    Don Burbach Guest
    Most likely a smoke detector or heat sensor tied to an alarm system.
    Be careful! I test the usual audio only smoke detectors using an aerosol smoke gas, but do not spray near or touch detectors that look like they may be part of an alarm system. Alarm system smoke detectors look more industrial and usually there is only one in a hallway, and is frequently next to the original detector on the ceiling. I do not want bring the local fire department or have the alarm company monitor get an alarm message.
    I specifically explain that an inspection of the alarm system is beyond the scope of a home inspection and suggest that the alarm company inspect their system. It is likely that a REO or short sale house is not covered by an alarm service(nobody's paying the bill!), or we don't have enough info to satisfy the alarm monitor like the code, security phrase, etc.
    I just don't want to deal with an screeching alarm that annoys an agent or client.
    Why is everyone always mentioning the fear of annoying a realtor?
    Do you really know who your client is?
    jimsonburg's Avatar
    jimsonburg Guest
    It looks like supervised carbon monoxide detector (Linear DXS-80 Carbon Monoxide (CO) Detector) with built-in transmitter, It is supervised for low battery and sends hourly status signals.
    Mar 2009
    Quote Originally Posted by jimsonburg View Post
    Thanks for the specific reference...it does look very close to the DXS-80
    My inspections take way too long as it is primarily because my curiosity has me exploring things beyond the SOP's....but I draw a limit at taking down plastic devices with flimsy breakable tabs...
    This would be great...is it an industry standard or you're experience with some number of devices ?
    Frank Kurz's Avatar
    Frank Kurz Guest
    This is an Ademco 5806W3 wireless smoke detector. Here's a link to the Honeywell site. 5806W3 - Honeywell Security & Communications
    The AC smoke alarm located adjacent to it is required to be installed by code. Most security installers won't touch them which is why you wind up with two detectors on the ceiling in many homes with security systems.
    Mar 2009
    Thank you for the link Frank.
