Results 1 to 3 of 3
    Scott Lynch's Avatar
    Scott Lynch Guest
    Default Electrical cables contacting each other
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Default Re: Electrical cables contacting each other
    What are the cables in question? Power and control wiring ?
    That's called "bundling" and causes those to need to be derated. 4-6 conductors are to be derated to 80%, which would still be on a 15 amp breaker.
    Not that I like it, but with just those two there, I would write it up, but not make a big deal about it. It will likely not affect the furnace, and the attic light will be nowhere near rated amperage for that circuit, so derating would not affect the attic light at all.
