    Default Cartridge style fuse size
    Any way to determine the size of this fuse without withdrawing it?
    David Banks's Avatar
    David Banks Guest
    Default Re: Cartridge style fuse size
    None that I know. If it is the Main I ask the Owner or Realtor to call the owner and ask if it is OK before I pull the Main. Also check for any computers.
    Houston, Texas
    You don't even know if there are fuses in it at this point. You could pull it and find the fuses have been replaced with a couple lenghts of copper water pipe. Stranger things have happened!
    Any chace that is just a disconnect without fuses, similar to A/C disconnects? I have not seen that particular style before.
    "Any chance that is just a disconnect without fuses, similar to A/C disconnects? I have not seen that particular style before.?"
    I hope not - that's sitting between the meter and a (maxed out) 30 breaker load-side panel with no main disconnect....
