Results 1 to 9 of 9
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cabinet track lighting
    Kitchen in a Condo/hotel room with track lighting under kitchen cabinets. Built in 08. Does this junction or splice need to be in a box.
    Atlanta, Georgia
    Default Re: Cabinet track lighting
    Yes. Any 110 wiring splices should be in a junction box.
    Aug 2008
    Are the lights 120v or LV? That looks like it might be a splice block that some manufacturers use.
    I think they are LV and i could not tell the block was wrapped in tape.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Is that not a transformer in the first picture?
    Daniel Mummey's Avatar
    Daniel Mummey Guest
    That would be nice! This is what you report as a "Temporary" connection.
    It is low voltage lighting, so either 12 or 24 volts. Are we still worried about those connections?
    Low voltage or not, whats the differance?
    Those wires look to be feeding the transformer (120vac), therefore the taped connection is wrong.
    Low voltage or not, whats the difference?
    No, they are the leads from the tranny to the lights. The heavier wire can carry more current without getting hot. Is there a shock hazard? Fire hazard?
    I was just working on the wiring for tailights on my utility trailer. Tape's OK for that. Low voltage and not much current.
    You can get a nasty shock from a 12 v car battery, but you have to work at it to get the full whammy of current. You need to be standing in salt water and then with wet hands, reach into a boat and twist both battery terminals.
