Thread: Service drop
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Service drop
    Do there connections on the service drop need to be wrapped.
    Default Re: Service drop
    4 little pics don't equal 1 big one.
    Compared to some of the junk we see, that looks like an OK drip loop to me. The owner of the property can ask for it to be checked.
    Yeah those pics sucked, don't know what happened there.
    Aug 2008
    They look like a plastic clamshell insulator. Are you concerned about the open end?
    Tony Cole's Avatar
    Tony Cole Guest
    Yes, Depending on where they are
    When you took the picture, could you reach them? In other words, are they adequately guarded? As to be normally unreachable? In other words, would the normal person, while cleaning gutters or doing normal maintanence be able to touch these wires?
    Per NESC 164 A.
    "Insulation
    Ends and joints of insulated conductors, unless otherwise adequately guarded, shall have insulating covering equivalent to that of other portions of the conductor."
    You got the rusted valley, right?
    Jerry the roof is trashed
