Results 1 to 13 of 13
    Aug 2009
    Raleigh
    Default framing/sheetrock against panel cover
    Addition built in 2002 and permits on file. Maybe something changed after addition was built. They left one screw out at the upper left so the cover can be removed.
    Default Re: framing/sheetrock against panel cover
    Quote Originally Posted by Randall Clark View Post
    Screw or no screw required working space of 30 X 36 inches in front of the Panel is not present .
    The insulation is also wrong.......
    Aug 2009
    Raleigh
    I know. Very nice set up.
    Panel went in and permit signed off. Then framing and sheet rock went up. Needed to be one bay to right. Electricians do not typically care where they put things unless it is spelled out for them and some one follows behind to make sure. Most trades just don't care what the next has to do. They figure that the next guy will figure it out. Possible just poor planning by the contractor.
    Upside down, right?
    Upside down, right?
    The Kraft paper is exposed. The fine print on the paper says that it must not be exposed as it is a fire hazard.
    I was joking, of course. And I will continue to:
    The reason it's wrong for it to be upside down is that you can't read "The fine print on the paper...(that) says that it must not be exposed as it is a fire hazard".
    Sorry!! My allergies and the fact that we are out of coffee at the house, has taken my humor detector away for the day!
    They can do worse than that. Here's one I found last week.
    Depends on one's intent ...
    If the intent is to leave easily combustible material next to the electrical panel to increase the chance of fire to burn the house down and collect the insurance money ...
    On The Mason-Dixon Line
    Oh How Easy it is to sit back and blindly throw darts and make blanket statements when on does not have the information needed to make such statements
    Yes it's easy. Work with what you see and what your told. Then use 35 yrs experience. May be wrong, but have seen same thing happening many times. The scenario follows a pattern that repeats.
