Results 1 to 2 of 2
03-15-2011, 07:08 PM #1
Double Tapped - Stranded vs Solid
Determining if a double tapped breaker terminal is accetable or not, depends only on wether or not the breaker is listed for 2 wires (i.e. SD & CH). Wether the conductor is stranded or solid does not matter (i.e. two stranded ok but two solids not...), correct?
03-15-2011, 08:07 PM #2
Re: Double Tapped - Stranded vs Solid
