    Sep 2008
    so so, California
    Default Remote panel in crawlspace
    So, if there is accessibility to the panel and lighting in front of the panel in a crawlspace (that you can stand in), are there any other reasons why a panel cannot be installed here?
    Tom Thompson's Avatar
    Tom Thompson Guest
    Default Re: Remote panel in crawlspace
    Easy access is required with clearances 30" each side, 36" in front (some very by location) also standing headroom isn't crawl space
    Sep 2008
    so so, California
    Quote Originally Posted by Tom Thompson View Post
    Cool, thanks. But, I did have to crawl through a typical screen cover ( like you see out in Northridge every day) under the house and then it opened up to a pretty large area.
    Tom Thompson Guest
    That is not easy access
    Sep 2008
    so so, California
    I suppose you're correct technically...although I slipped in pretty easily at a buck fifty.
    On The Mason-Dixon Line
    30" of working space in width total. Not 30" each side of panel
    Jan 2011
    Utah
    I expect there is a service disconnect on the outside of the structure, at the meter base?
    Sep 2008
    so so, California
    Quote Originally Posted by Jimmy Roberts View Post
    Yea, its just a remote panel
