    mathew stouffer's Avatar
    mathew stouffer Guest
    Default 220 outlet in bedroom
    This is a first. Single family home built in the early 90's. This was located in the basement bedroom. Now you can weld as your get ready for bed
    Default Re: 220 outlet in bedroom
    Is there a window above or a wall space above grade which may have been later filled in.
    Not uncommon for through the wall AC or a PTAC unit. (Not unlike what you might encounter in a motel room).
    Cannot actually make out the NEMA style receptacle with side views.
    New York
    Can you imagine the size vibrator they must have?
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    LMAO!!!!!!!!!!!!
    Matt, you mentioned this was in a basement level bedroom. Any chance this room might have been a laundry room at one point?
    Edward Loughran's Avatar
    Edward Loughran Guest
    I see this with tanning beds more than A/C units
    Mar 2011
    Virginia Beach, VA
    Matt,
    It is actually for a vibrator as was mentioned earlier in this thread.
    However this is a full bed and beyond model vibrator and it can only be used by folks with excellent heart conditions.
