    Jon mackay's Avatar
    Jon mackay Guest
    Default How many wires per nut
    Is there a standard of haw many wires can be secured under 1 wire nut?
    This one has 5.
    Aug 2008
    Default Re: How many wires per nut
    It depends. The information is included on the packaging for the connectors. A typical connector like that is good for 5 #12s, but should be checked.
    MARVIN TOWNSEN's Avatar
    MARVIN TOWNSEN Guest
    As many as you can fit
    If you don't have the manufacture's chart handy, each manufacturer will have a have a link on their site to a document with the UL listing for each model and size of their connectors. For example here's the
    Ideal Industries listing for their standard "Wire-Nut" type connectors.
