Thread: flicking lights 1988 home
06-24-2011, 09:43 PM #1
Hi
need help on this lights in this house are flickering even when my bathroom fan is on the light flickers like the juice is being sucked out of the fan. only 4 upstairs lights are doing this downstairs no problems can one of you electrical experts tell me what can cause
06-24-2011, 10:20 PM #2
Re: flicking lights 1988 home
Hi Tony
Unfortunately this is not a forum for help with electrical problems by a homeowner. Post your question at the below link and you will get the help you want.
Electrical - DIY Chatroom - DIY Home Improvement Forum
06-25-2011, 12:26 AM #3
06-25-2011, 06:18 AM #4
If you have back-stabbed connections in that branch circuit, it could be a bad wire connection at one of the receptacles. But it could be a faulty breaker, or rats chewing on wiring in the walls. The fan increases the load, drawing more current thru the bad spot.
It needs repair right away. Get an electrician to fix it, before a hot spot bursts into flame.
06-27-2011, 08:37 AM #5
