    Mike Brewer's Avatar
    Mike Brewer Guest
    Question WIRE NUTS / SPLICES IN CIRCUIT PANEL
    What is the ruling with having wire nuts to splice any wires in the panel box
    before it goes into the breaker, the original wire looks like it was to short to
    make it to the breaker, so they added a short piece to make the connection.
    Default Re: WIRE NUTS / SPLICES IN CIRCUIT PANEL
    A panel box is nothing more than a big junction box. Splices are OK as long as they are done correctly. It is very common to find splices in a panel box, exspecily when it has been upgraded.
    What Scott said, ... as long as ... those conductors terminate *in* the panel and do not 'pass through' the panel.
    Just check to be sure the spliced wires are of the same gauge and not mismatched. I've run into some splices inside panels lately where the 12 gauge wire connected to the 20 amp breaker was fine but the wire downstream of the splice was 14 gauge.
    Paul Tooley's Avatar
    Paul Tooley Guest
    all of the above, AND there can be no more than two wires in the wire nut...
    __________________________________
    shock therapy is fun...the first time
    Ridgewood, NJ
    What if the wire nut is rated for more than two wires?
    Quote Originally Posted by Paul Tooley View Post
    Huh? Why not?
