Thread: CCAW
08-05-2011, 10:53 AM #1
08-05-2011, 10:55 AM #2
Re: CCAW
What year is the house?
08-05-2011, 11:13 AM #3
Re: CCAW
A townhouse built in 1976, Las Vegas, NV
08-05-2011, 12:08 PM #4
Re: CCAW
In my experience it has the same problems as any aluminum wiring that is used for branch circuit wiring. The wire is still soft and gets loose and can heat up at a connection or terminal.
08-05-2011, 07:06 PM #5
Re: CCAW
Copper clad aluminum is treated the same as aluminum wiring, it must have devices rated for aluminum wire.
Being as the wiring is the same, with the except of the copper cladding over the aluminum, it is susceptible to the same problems as aluminum wiring.
08-06-2011, 06:45 AM #6
Re: CCAW
CU clad AL is sized like aluminum but can be terminated like copper, there are many wiring devices that are marked "CU or CU clad wire only", there is no other reason to have CU clad AL.
IMO, any aluminum conductors smaller then 6 AWG is a bad thing, but "low bid" rules the roost.
08-06-2011, 04:38 PM #7
