Results 1 to 10 of 10
Thread: Service Connection
09-15-2011, 05:59 PM #1
Service Connection
This was next door to my inspection and it caught my eye
09-15-2011, 06:11 PM #2
Re: Service Connection
09-15-2011, 06:20 PM #3
Try again
09-15-2011, 06:34 PM #4
09-15-2011, 07:48 PM #5
The wire nuts and tape just didn't look right at a distance. At least he left the utility barrel connectors in place so he could wire nut copper to copper:-)
Here is another one I came across about 3 years ago.
09-16-2011, 08:06 AM #6
09-16-2011, 08:58 AM #7
PO put an un-permitted addition on the back of the house. He installed the new service on the back of the addition (20 feet closer to the utility pole) and since he had some extra wire fed the live service wires into the panel. No splices of the conductors at the weather head.
Around here all the utility splices are barrel connectors. Some of the older connections may be split bolts.
09-18-2011, 11:46 AM #8
Looks like a galvy plumbing roof flange... as opposed to a listed elect roof riser plate. I'm getting tired of writing this one up. ugg
09-19-2011, 04:38 AM #9
Ha, ha!...I don't think that's a "Neutral". I think that's a "Roof Anchor". He spliced a neutral into a support cable! Well, at least he found someting to connect it to. "Huuuumm,,,,two hots soooo...THIS one must be the neutral". Bad news for squirrels around that house.
09-19-2011, 06:10 AM #10
