Results 1 to 2 of 2
Thread: disp + DW on double pole breaker
09-18-2011, 10:59 AM #1
This is the first time I've seen this. The dishwasher and disposal are on a multi wire circuit like we usually see. However, in this case, instead of two individual single pole breakers, they are connected to a double pole breaker with a common trip (normally seen on 240v circuits). The breaker takes up two spaces on the bus so each item is fed by a different phase. They share a neutral in the NM 14/3 cable.
In my own mind I believe this is acceptable but I just want to make sure.
Is it ok?
09-18-2011, 11:29 AM #2
Re: disp + DW on double pole breaker
Nevermind....I found my answer here > http://www.inspectionnews.net/home_i...-circuits.html
Thanks for the previous posts.
