Results 1 to 3 of 3
    Steve Miller's Avatar
    Steve Miller Guest
    Default Electric Dryer and Range Bonding of Neutral
    When inspecting a property do you check the 30 ampere, 40 or 50 ampere cord caps and receptacles on existing branch circuits and the existing bonding of the neutral?
    NHIE Practice Exam
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Electric Dryer and Range Bonding of Neutral
    Quote Originally Posted by Steve Miller View Post
    About as far as I go is looking at the wire in the panel to see if it is a 3 wire or 4 wire cable. If I see a 4 hole receptacle with a three wire cable I write it up as a possible grounding problem.
    Kalamazoo, MI
    Steve,
    As a seasoned inspector with over 15 yrs of experience I would be lying if I said I did. There is a lot we inspectors need to look at besides the electrical (i.e. service entranc, main and auxillary panels, wiring, switches and outlets) in a home. You need to draw the line somewhere (and that's usually with the standards of practice of the NAHI and/or ASHI).
    RJDalga
    http://homeanalysts.com
    Kalamazoo, MI
