Results 1 to 9 of 9
10-11-2011, 07:31 AM #1
Is this a Smoke or Carbon Monoxide Detector
I need help indentifying the device in the attached picture. I assume it is either a smoke or carbon detector but could't tell. The house was built in 1974 and there was only one other detector (obviously a smoke)installed in the hallway along with this one. Other than "do not paint" there were no markings I could see on this one. I tried to twist the cover off with light pressure, but no going. There was a propane fired log set installed in the living room. The house had no security system installed.
Thanks.
10-11-2011, 09:40 AM #2
Re: Is this a Smoke or Carbon Monoxide Detector
It is a UFO.
Go back, make sure it is de-energized in case it is line voltage(120v), and get the darn thing down. Try putting slight upward pressure on the device as you twist.
10-11-2011, 09:46 AM #3
10-11-2011, 12:48 PM #4
10-11-2011, 01:14 PM #5
Check this out
Heat Detectors Recalled by Interstate Engineering
10-12-2011, 10:22 AM #6
Wow. Great catch!
10-12-2011, 10:39 AM #7
Thank you for all the replies ...
Rick ... I owe you one for making go from not knowing anything to looking like a genius.
10-12-2011, 11:09 AM #8
The article says it may be a heat detector, then it shows a pic of the UFO agin. I don't get it. Did it fly from there?
10-12-2011, 04:58 PM #9
