Results 1 to 13 of 13
    Utah
    Default Random Light Dimming
    I know very little about electrical so I could use a little help from from sparky types.
    This is personal.
    The lights in my house seem to randomly dim. I can associate some dimming when other appliances kick in such as when the microwave is used. But other times, like this morning before anyone else was up, the lights in my bathroom dimmed and stayed dim.
    I know I can call an electrician and probably will, but I was wondering how one would go about diagnosing this problem?
    Default Re: Random Light Dimming
    Quote Originally Posted by Rod Butler View Post
    This is personal.
    Call your Locale Utilities Provider tell them the lights is Going Crazy and your Scared The House is Gonna Burn Down !
    Most likely the Neutral is loose at he Service Entrance. ( The Dramatic Phone Call should move you up from a week out on the repair list.
    Utah
    Actually that's not a bad idea. The service box does seem to be pulling away a bit from the wall. I hate to admit this but I will have to drain and move my hot tub first as it is too close to the panel.
    Sheesh, I am embarrassed.
    georgia
    As Billy stated most likely a loose or lost grounded conductor but without testing the system you will not know where, it could be a power company issue but could also be within your panel or service. The problem need imediate attention due if this is the problem because one phase will have a low voltage causing the dimming but the other phase will have high voltage that will cause damage to the equipment that is connected.
    Possible bad connectin on leg in meter. Arcing taking place. Utility service povider can make determination. Who replaces it seems to varry
    I had a similar issue a few years ago. It was a bad neutral at the service head.
    Robert Meier's Avatar
    Robert Meier Guest
    As suggested it sounds like a neutral problem which should be addressed immediately. For one as Paul mentioned you could fry equipment with an over voltage condition, secondly depending where the neutral current is now going it could be a fire hazard. If the POCO can't get there quickly I would call an electrician.
    The lights are dimming because the voltage is dropping, the voltage is dropping because there is a loose or bad neutral (as the others have said), but the flip side of that is that *the voltage on the other phase leg has increased* - and that ain't good at all.
    Healdsburg, CA
    While you're at it relocate the hot tub or a loose neutral will be the least of your problems.
    Darrel Hood's Avatar
    Darrel Hood Guest
    Last year, I encountered several panels that had loose lugs. These had the same symptoms.
    Apr 2009
    NY State
    Dimming AND brightening is a sign of a loose or open neutral.
    A drastic dimming is a sign of a loose or compromised hot leg.
    A slight dimming is, or can be, perfectly normal.
    Quote Originally Posted by Speedy Petey View Post
    perfectly normal.
    Now there is an oxymoron ... perfectly ... normal ...
    Utah
    Just a little update . . .
    I finally got around to calling the power company (hey I've been busy) and when I told the guy how long this has been taking place he sounded a bit concerned.
    Thirty minutes later I got a text from my son at home and he said the guy from the power company was there and said their line into the panel was bad and they were putting a temporary feed in for a few days and will finish it up as soon as a work order can be generated.
    The power company will not secure the panel to the wall even though their meter is on it. He did show my son how easy it is to fix without removing the meter.
    Hope this fixes it.
