Thread: Outlet along countertop
01-31-2012, 07:02 AM #1
This small table/countertop was anchored to the column which is boardering the kitchen. SFH built in 1992, I mentioned a missing outlet. Is this a toss up or would you categorize this as a countertop as well.
01-31-2012, 07:06 AM #2
Re: Outlet along countertop
Good question. The fact that it's permanent makes it a countertop IMO.
01-31-2012, 06:31 PM #3
01-31-2012, 06:34 PM #4
01-31-2012, 07:35 PM #5
I'd tell them if they want to put the toaster there, they should get a wireless.
02-01-2012, 11:40 AM #6
looks like a table to me , not a counter top.
side note: would you consider that support column a wall or a column ? Looks like a column to me
The NEC states that counter top receptacles shall be installed at each wall countertop space that is 12" or wider
02-01-2012, 07:32 PM #7
A countertop NOT
