Results 1 to 15 of 15
Thread: Breaker Labling
02-22-2012, 07:33 AM #1
Breaker Labling
Aluminum wire connected to 50 amp 240 volt breaker. Breaker is labeled CU Only, but once I got home to finish the report I see the label also has CU/AL on it. How is this label to be interpreted?
02-22-2012, 07:58 AM #2
Re: Breaker Labling
Confusing to say the least. However, if I were to guess I would say that CSA has only listed the breaker for use with copper. I don't know why they would list it differently than Siemens.
Might be time for a phone call to Siemens Tech Support.
02-22-2012, 10:29 AM #3
Re: Breaker Labling
The CU only is above the column for amperages 35 or under. The breaker is listed for aluminum for 40 to 50 AMPs.
Yes, confusing. The "cheap at any inconvienience" shows up here in the form of being too cheap to make a stamp for different sizes of breakers.
02-22-2012, 10:31 AM #4
Re: Breaker Labling
Why I have to carry copies of manufacturer's catalogs around in the "smart phone" for building inspections.
02-22-2012, 02:11 PM #5
Re: Breaker Labling
Are these CB's feeding AC units? Otherwise the conductors look a little small.
02-22-2012, 03:10 PM #6
Re: Breaker Labling
Yes, to AC units
02-22-2012, 10:03 PM #7
Re: Breaker Labling
The wire connector screws don't look right to me. They appear to be simple slotted screws, and not combination slotted/robertson screw heads from what I can see in the first photograph of the four wire connector screw heads I can see in the first photograph in various positions. I may very well be mistaken, but I thought all residential Siemens QP breakers had combination slot/robertson wire connector screws on them.
I'm also not recalling EVER seeing a black label on a SIEMENS QP Breaker wherein SIEMENS hasn't been in ALL Capital Letters.
I'm also wondering why I am seeing the word "Listed" (in upper & lower case) to the right of the UL insignia & trademark lacking a US lower right of the UL insignia circle; and not below same, and how the word "Listed" has been run together with an abbreviated description. I am further concerned as to the improper proportion appearance of the CSA insignia and the lacking trademark mark which is always to the right center of the open C, as discussed in the second link whitepaper from CSA on Counterfeiting products and the improper use of their insignia marks dating back to 2002; and some other "typesetting" concerns on the labels.
I am suspicious that the pictured may be counterfeit. Unknown age of what is pictured, and obviously more details would be necessary to explore/confirm with the manufacturer, including the breaker side view and label information (origin, date code, etc.).
See white paper from Siemens attached. Although it focuses more on the 15 & 20 Amp QPs it does address the issue in general.
Contact information is included in the attached. If you prefer to read the Siemens white paper from last year on line it may be viewed here: http://www.sea.siemens.com/us/intern...terfeit_WP.pdf
CSA's whitepaper on counterfeiting anti-counterfeiting efforts, hosted on NEMA.org's website: http://www.nema.org/gov/anti-counter...te_paper_e.pdf
Last edited by H.G. Watson, Sr.; 02-22-2012 at 11:51 PM. Reason: added link to CSA whitepaper regarding suspect mark
02-22-2012, 11:37 PM #8
Re: Breaker Labling
HG you are a paranoid old..... :-)
20 year old house. I assumed the breakers are original except for one or two of the branch circuits. The house is vacant and the panel is accessible so I might just have to go back and get a few more photos. I won't be in the area tomorrow but possibly Friday.
I'll let you know
02-23-2012, 06:37 AM #9
Re: Breaker Labling
Looks like the breaker is copper only for Canada, since the OP is in Bakersfield, what it is listed for in Canuckistan is irrelevent.
02-25-2012, 01:01 PM #10
Re: Breaker Labling
A few more photos of the suspect breakers.
Rollie, please explain about the Canadian listing.
02-25-2012, 10:01 PM #11
02-25-2012, 10:09 PM #12
02-25-2012, 10:49 PM #13
Re: Breaker Labling
Perhaps when these were made the CSA knew something UL didn't, and listed them the way they did for good reason. Just because they're in a different country doesn't make them any safer.
- James Burgh, 1754.
02-26-2012, 08:11 AM #14
02-26-2012, 08:49 AM #15
Re: Breaker Labling
The first photo in Don's followup post/series clearly confirms that the wire connector screws are simple slot-only type and that
Combination slot/robertson wire connector screws are not present.
Would have expected combination slot/robertson wire connector screws for January 1992 mfg and esp. for Canadian approval/market labeling.
Suspected counterfeit, the panel as well, suspected counterfeit/bootleg.
The hotline number and contact information for SIEMENS has already been supplied earlier. Suggest verification of authenticity or suspected counterfeit-ness with Manufacturer.
