03-21-2012, 09:28 AM #1
Torn in Sheatrhing on Service Cable
Is there any acceptable repair that can be made when the sheathing on a service entrance cable is torn? I had heard an electrician in my area say it is against BOCA code to wrap the damaged sections with tape and that full replacement of the cable is the only option.
This picture isn't the best but you get the idea.
Wow, I really messed up the title of this thread. It should read Torn Sheathing on Service Cable
Similar Threads:Last edited by Nick Ostrowski; 03-21-2012 at 09:36 AM.
03-21-2012, 10:55 AM #2
Re: Torn in Sheatrhing on Service Cable
Probably lots of materials that would adequately protect the cable, but none of them legal. Replacement is the only legal option. I have never understood how manufacturing got approval for surface mounted, un-fused cable. S.E. cable is almost identical in construction to typical "NM" / romex cable; just bigger. Yet NM cable cannot be surface mounted anywhere it is subject to physical damage and it is far more safely overload protected than incoming utility wires.
03-21-2012, 01:14 PM #3
IMO the only legitimate solution is to replace the SE cable.
03-21-2012, 01:26 PM #4
03-21-2012, 02:30 PM #5
From the small amount shown in that photo, more than just some cable needs replacement.
03-21-2012, 03:07 PM #6
03-21-2012, 04:44 PM #7
I believe the vinyl siding was installed around the existing meter box and service cable install which likely explains it's appearance.
03-21-2012, 05:12 PM #8
