    Jan 2011
    Marietta, Georgia
    Default Who knows something about this panel
    Gentlemen,
    Inspected a 1968 home with a type of main panel box I have never before seen. The breaker design was foreign to me. Anyone have any past experience with this design? Like, how to reset a breaker? How reliable is it at this age, ect. Thanks in advance.[ATTACH]25405
    Robert Meier's Avatar
    Robert Meier Guest
    Default Re: Who knows something about this panel
    Looks like a Bulldog Pushmatic panel with a fused main. The center of the CB is pushed into cycle it on and off.
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    What Robert said. That upper assembly is the main disconnect. You cannot switch or tirn it on/off. The handle on that upper assembly is there to pull it completely, ( physically ), out; fuses & all. If you do that, the panel is dead / disconnected.
    Dec 2007
    Chico,Ca
    If it's 1968 vintage then it would be a ITE Pushmatic panel, if one were to pull out the 200A pullout, it prob. is stamped "ITE Circuit Breaker Company, Walker Div".
    Pushmatic was the only residential bolt-on type breaker panel, other then old & obsolete nothing wrong w/ them, not like a Zinsco of the same era where it was crap when it was still in the box on the distributors shelf.
    Georgetown, KY
    It's a pushmatic but a clear picture of the label certainly would have helped identify it as ITE or Bulldog.
    Jan 2011
    Marietta, Georgia
    Thank you all for the information. It is an ITE, Walker out of Atlanta, I do recall seeing that on the labeling.
    Apr 2009
    NY State
    Pushmatics were considered some of the best residential breakers going, in their day.
    About the only issues I see these days is failure to reset. Sometimes breakers when turned off or tripped can be very difficult to press back in.
    I have not seen any issues with failure to trip like many older FPE breakers.
