Results 1 to 20 of 20
    Apr 2012
    Palm Springs, CA
    Default Who should we fire first?
    Apr 2009
    NY State
    Default Re: Who should we fire first?
    Other than the missing plate (extremely minor issue), what's the problem?
    Who are you looking to have fired?
    Quote Originally Posted by Speedy Petey View Post
    I Vote for The Painter.
    Apr 2009
    NY State
    I agree.
    The correct answer would be the original poster. The correct wording would be "Whom should we fire first?"
    Apr 2012
    Palm Springs, CA
    Not looking to have anyone fired. I guess I need to learnith my English first.
    Jul 2009
    Lanham, MD
    Quote Originally Posted by Todd Edly View Post
    Gas line shut off next to outlet that is missing cover plate for stove....
    Forget the missing plate. I see a much more dangerous situation -- Hard to tell from the picture but do I see a 1/2" nipple screwed into a 3/4" nipple or pipe? Look closely at the threads on both nipples/pipe. It sure doesn't look right! Definitely not a 3/4" x 1/2" bushing.
    Quote Originally Posted by Steven Saville View Post
    Ye ow!
    Looks like Male in Male Connection.
    * Does The President Approve of this type of Gas Coupling?
    ** Todd don't let The Preposition Police Get to you. ( Gunman can't hep himself.)
    Oct 2011
    Minneapolis, MN
    Thank you! You made me laugh. I needed that.
    ("preposition"?!)
    - James Burgh, 1754.
    Since its a toss-up between the plaster skimmer and the gas-fitter/plumber Safety tips the scale and I'd say the gasfitter/plumber (however from the looks of things there hasn't been any gasfitting/plumbing tinkering going on in a long while.)
    Probably all the same party - looks like typical flip work.
    Robert Meier's Avatar
    Robert Meier Guest
    Seems to be the only issue. That and the receptacle installed ground up.
    Just kidding.
    Just kidding.
    Not ground up if you are lying on your back to install receptacle. It is all about perception and orientation.
    Dec 2007
    Chico,Ca
    There are 1/2" IPS female X 3/4" ips male adapters, mostly flare fitting adapters for gas flex, w/ the limited info in the picture no intelligent conclusion can be made.
    Aug 2008
    Guess you were too young to see this on the news?
    Look closely at the tower and you can just see the receptacle near the top.
    Gosh Rollie is the op photo flex ?
    What was on the Market this time frame in Black Pipe that would even remotely make this an approved connection ?
    Dec 2007
    Chico,Ca
    Until we see what is on the other side of the plastic at the top of the photo, a proper answer cannot be given, it is WAG until then.
    Look closer. Start by looking at the binding terminals. When you note whats wrong there at that level of magnification, explore further.
    Robert Meier Guest
    Guess we all missed that one.
    Here Ya Go.
    Dec 2007
    Chico,Ca
    Here Ya Go.
    My point exactly, a WAG.
