Results 1 to 20 of 20
Thread: Who should we fire first?
05-21-2012, 04:36 PM #1
Gas line shut off next to outlet that is missing cover plate for stove....
05-21-2012, 05:13 PM #2
Re: Who should we fire first?
Other than the missing plate (extremely minor issue), what's the problem?
Who are you looking to have fired?
05-21-2012, 05:24 PM #3
05-21-2012, 05:25 PM #4
05-21-2012, 06:17 PM #5
The correct answer would be the original poster. The correct wording would be "Whom should we fire first?"
05-21-2012, 06:50 PM #6
Not looking to have anyone fired. I guess I need to learnith my English first.
05-21-2012, 06:53 PM #7
Forget the missing plate. I see a much more dangerous situation -- Hard to tell from the picture but do I see a 1/2" nipple screwed into a 3/4" nipple or pipe? Look closely at the threads on both nipples/pipe. It sure doesn't look right! Definitely not a 3/4" x 1/2" bushing.
05-21-2012, 07:03 PM #8
05-21-2012, 09:06 PM #9
- James Burgh, 1754.
05-21-2012, 09:54 PM #10
Since its a toss-up between the plaster skimmer and the gas-fitter/plumber Safety tips the scale and I'd say the gasfitter/plumber (however from the looks of things there hasn't been any gasfitting/plumbing tinkering going on in a long while.)
Probably all the same party - looks like typical flip work.
05-21-2012, 10:48 PM #11
05-22-2012, 03:42 AM #12
05-22-2012, 05:58 AM #13
There are 1/2" IPS female X 3/4" ips male adapters, mostly flare fitting adapters for gas flex, w/ the limited info in the picture no intelligent conclusion can be made.
05-22-2012, 06:24 PM #14
05-22-2012, 06:36 PM #15
05-22-2012, 08:15 PM #16
05-22-2012, 09:05 PM #17
05-22-2012, 11:10 PM #18
05-23-2012, 05:45 AM #19
05-23-2012, 05:53 AM #20
