Thread: Input please
    Oct 2007
    Arizona
    Default Input please
    Hi guys,
    I have not come across anything like this before and would appreciate your input. This is from a 1966 house with an FPE panel, so it already has it's issues. I operated the switches inside the home and could hear a buzzing in this panel which was in the pantry. Are these transformers to a low voltage system? If so...what was the design in mind and why did I hear buzzing? Any immediate safety issues? With my experience could not offer much other than review/repairs by a licensed electrician.
    The clients walked due to multiple issues, but I'd like to know for my own peace of mind. As always..thank you for your feedback and knowledge.
    Chris
    Inspection Referral SOC
    Default Re: Input please
    That is a low voltage lighting system.
    A low voltage switch operates one of those relays and the relay turns the light on or off.
    You likely noticed that the switches were quite different, definitely not regular lighting switches, right?
    Oct 2007
    Arizona
    Correct...kind of retro cool...maybe they'll make a comeback
    Look into Touch-Plate Electro-Systems - looks to be what you have in this and the other thread you started (same home, picture of plate-mounted switch).
    A buzzing sound from a transformer means it needs to be replaced. They can heat up and short out, causing smoke damage or possibly a fire in the panel.
    So the house needs rewiring of light switches as well as a new breaker panel. Ouch.
