Results 1 to 10 of 10
		Thread: Service wire - material
	08-02-2012, 04:43 AM #1 Service wire - material Service wire - materialThis is a 60's house and the service wire is typical for houses this age.
 What is the material of this wire? It looks like steel cable or is this clad copper?
 Also, What is the expected life span of the wire (or sheathing)? Should we be recommending that a service wire of this type be changed due to age?
 Thanx
	08-02-2012, 07:12 AM #2 Re: Service wire - material Re: Service wire - materialThe wire itself is probably aluminum, don't know if they used steel. Jerry or HG would know better than I.
 However, in my experience the insulation is the big problem. As long as you don't touch it, look at it too long or talk bad about it in its presence the insulation tends to remain intact.
 Look at it too long, touch it and it seems to flake off happily. The pic looks like it might be that slightly plastic'y type. That stuff isn't any better, falls of in chunks.
 Looking at the wire thats in the panel and the wire as it goes into the weather head are the key exposure areas. I tell clients to have anyone be very careful about disturbing the wires. i.e. don't have your buddy install some romex line and jostle those wires. I also tell them to consider replacement sooner rather than later.
 Recommending replacement isn't the worst scenario since there's usually other issues of age, deterioration or non-compliance that need to be addressed anyway.
	08-02-2012, 09:19 AM #3 Re: Service wire - material Re: Service wire - materialThat is rough lookin stuff. Probably tinned copper. With no exposure to the elements it should last lots longer than any of us. Not sure when the code requirement came to be, but that main C/B is not legal - - - required to be bolted, ( secured ), to the can.
	08-02-2012, 09:32 AM #4 Re: Service wire - material Re: Service wire - materialHere's a larger picture of the wire.
 It sure doesn't look like aluminum.
 The main breaker is not labeled Al/Cu.
 Type MP-T - not sure what that means
	08-02-2012, 02:21 PM #5
	08-02-2012, 02:23 PM #6
	08-02-2012, 03:08 PM #7 Re: Service wire - material Re: Service wire - materialLooks like tinned copper in rubber insulation, but that would be unusual in a 1960s house ... in a 1930s, 40s, maybe even 50s, yes.
 By the 1950s thermoplastic insulation had come in, by the 1960s I would have thought that rubber insulation was gone and thermoplastic would have replaced all it. Possibly the thermoplastic was on the smaller size conductors - I'm trying to remember what I worked with in the mid-1960s with the larger sizes, as I recall, the smaller sizes were all thermoplastic insulated.
	08-02-2012, 05:57 PM #8
	08-02-2012, 08:21 PM #9
	08-02-2012, 08:51 PM #10 Re: Service wire - material Re: Service wire - materialI agree with all, it looks like tinned copper with rubber insulation. Maybe an old timer was using up the last of his old stock?
 What about that bare neutral? Now that looks like Aluminum. Would they sometimes tin the bare stranded cable? I need to go look at some other pics.
 Re: really old SEC's, I will generally take a look at the wiring at the drip loop, and include a pic of that. It will be the worst for wear at the loop.
