Results 1 to 13 of 13
Thread: What does this mean?
08-08-2012, 10:08 AM #1
Here's a new one for me. All three lights lit-up like a christmas tree.
Not even on the legend of the tester. What is the problem with this circuit?
08-08-2012, 10:55 AM #2
Re: What does this mean?
Welmoed Sisson
Inspections by Bob, LLC, Boyds, MD
"Given sufficient thrust, pigs fly just fine."
08-08-2012, 01:42 PM #3
That's great info!
08-09-2012, 06:48 PM #4
08-10-2012, 04:53 AM #5
I ran into this a couple of years ago. A young couple from Germany (engineers working for local company) wired one receptacle in the laundry room with 240 volt. Do not know why but was told they did bring their appliances with then from Germany. They use 240 volts in Germany supplied in a small receptacle we use with 120 volt???? I agree, learn how to use and always carry a volt meter.
08-10-2012, 05:41 AM #6
08-10-2012, 07:19 AM #7
Don,
Wiring a 110v recepticle with 220v would not work for appliances from Europe. The reason is that they are single line 220v appliances and using two 110v legs would burn them up. You would need a step up transformer to convert 110v to 220v and then it would work.
Chris,
If you step up from 110v to 220v, you would still be able to use some appliances like heating elements (coffee maker, toaster) and motors (electric drill, saws, etc.), as well as some electronics, but not all.
I lived in Europe for 13 years and have a lot of tools that I still use on a step up transformer. I also used a lot of tools in Europe that I took with me on the same transformer using the step down function. I also have a computer printer that I still use on a small step up transformer. There is no noticable difference in the performance of these items because of the change in cycles.
08-10-2012, 01:35 PM #8
I think probably an open neutral, or it could be two faults.
You'd have to be way out to lunch to get 240 volts on that simple receptacle feeder.
Here's some more on the subject. I cropped some of it:
Circuit tester question
- I ran into it once. The neutral opened up and fried a nice lady's boombox. We tested it with a plug-in tester and all three lites came on. The multimeter said 208v across the two slots in the receptacle, 120v from each to ground. Traced it back one box and found the neutral out of the wirenut.
08-10-2012, 03:20 PM #9
08-11-2012, 04:40 AM #10
Chris,
My understanding is that the step-up/step-down transformer only changes the voltage, but does not change the Hz (at least mine doesn't). Not sure if there are models out there that do. I used my U.S. model skill saw, trim router and mitre saw in Europe and here I still use my EU model sander, hammer drill, router and printer with no noticeable difference. I've been told that 50Hz motors will run faster on 60Hz and vice-versa. Not sure if it's true, but I couldn't tell the difference.
08-11-2012, 06:16 AM #11
08-11-2012, 08:12 AM #12
Have you read the manufacturer's instructions/user's manual?
WAGs, suspect MWBC: something is "plugged" into other half (esp. "power supply"), and/or half is open; concern electrical contact btwn tester & conductive plate, questionable grnd of a receptacle & mounting of a receptacle to metallic wiring method as ground, and/or non-isolated neutral making contact with box. DIYer may have tapped off a switch supplied receptacle, or replaced receptacle where originally just half was switch controlled and/or other half was supplied by different circuit and failed to break both tabs - or crossed neutrals where sourced from multi-gang box elsewhere. i.e. backfeed or leakage on neutral.
Without further diagnositcs, investigations elsewhere, circuit tracing impossible from afar.
Never use with a MWBC, never use with ungrounded circuits. presence of a GFCI receptacle ahead may suggest the original wiring system lacking shared neutral after division of MWBC; a grounding conductor or presence of EMT for part of the circuit is no assurance it is solidly grounded throughout.
From instructions for tester (sadly lacking schematic/wiring diagram) under "Standard Receptacle:
"3. The tester will not indicate the qulity of the ground connection, 2 (two) hot wires in a circuit, a combination of defects, or reversal of ground and neutral conductors."
08-14-2012, 03:48 PM #13
