Results 1 to 3 of 3
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Splices in Carrier furnace
    New home. Is this acceptable?
    Aug 2008
    Default Re: Splices in Carrier furnace
    Besides the lack of a connector, what is the wiring method?
    Does this look different than other gas furnaces you have seen to raise the question?
    The missing bushing around the power cord at the penetration into the cabinet is one. Other than that I was curious above the splices. The splices are dedicated to a UV air cleaner and steam humidifier. Do they need to be housed in an external junction box or does the cabinet of the furnace serve as a box.
