Results 1 to 11 of 11
    Default another reason to change over to gas
    The winterizing people put that blue tape on, if anyone is wondering.
    Apr 2009
    NY State
    Default Re: another reason to change over to gas
    NICE newer service change. LOVE the SEU run.
    Mar 2012
    Michigan
    Is that a water line resting atop the unit? Nice.
    Everything has its beauty but not everyone sees it.
    Apr 2009
    NY State
    Quote Originally Posted by Richard Skalski View Post
    No. It's a curtain rod. See all the rings.
    Quote Originally Posted by Speedy Petey View Post
    Those look like fins for an in-line heater over the door. Guess they were getting cold drafts upstairs when the door opened so they thought they would warm that air before it blasted the floor above.
    I would almost bet it is a broom stored overhead, and not radiant fins.
    John,
    What say you?
    John,
    What say you?
    Yep. Radiant fins.
    John,
    What say you?
    Yep. Radiant fins.
    I concede.
    Oct 2009
    michigan
    What be wrong wit da SEU? It has mechanical protection, at least until someone goes and removes da oiler
    Nov 2011
    Oregon, USA
    That's painters' tape, isn' t it? "Winterizing people" in your area also work as house painters?
