10-31-2012, 03:19 PM #1
Main water line next to service panel
Inspecting a house today built in 1970 and found the water main water line entry is beside the electrical service panel. Is there a violation with this?? Thanks
10-31-2012, 03:51 PM #2
Re: Main water line next to service panel
"next to" - okay ... not smart, but 'okay'
"over" - baaad ... and not smart
10-31-2012, 04:59 PM #3
I have called out two main water shut offs located above over a bit...if the tap ever started to leak, while using it. buzzzzt...in both cases re routing the plumbing was a very simple fix...but my mind still has trouble thinking that they actually installed it that way. The second trade should have said something...the AHJ should have said something....
11-01-2012, 07:18 AM #4
in my area there was no building dept till 1972 or so. i have seen that many times and always call out the hazard and an upgrade recommendation.
i also have found quite a few bathrooms added above with the toilet right above the panel. brings a few desciptive terms to mind
11-01-2012, 05:34 PM #5
If some thing appears to be a hazard,call it out,better to be safe than sorry,of course common sense should prevail.
11-02-2012, 06:43 AM #6
An example of violating common sense but not code. However, note the galvanized to copper connection.
11-02-2012, 08:07 PM #7
