Results 1 to 9 of 9
10-31-2012, 09:26 PM #1
Warm breakers, how much is too much?
Pair of 60-amp double-pole breakers for an electric force air furnace. Both were warm to touch when the furnace was running. My infra red thermoter showed 92-114 degrees. Side note, the panel is in an old basement, so the ambient temp was in the 60's.
I have only see a couple of electric furnaces before, so don't know if this is unusual. Didn't see anything else alarming in the wire run or at the furnace.
How warm would be considered to be too warm?
10-31-2012, 09:48 PM #2
Re: Warm breakers, how much is too much?
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
10-31-2012, 10:04 PM #3
Hey man, back in dem days of disco, I was HOT!!!. Me and Travolta. Boy oh boy.
Sorry. long day.
Ok - so what is a disco temp? I probably didn't take it.
10-31-2012, 10:12 PM #4
11-01-2012, 01:31 AM #5
As I said originally
So we're talking about a rise of 40-50 degrees on the surface of the breaker as compared to surrounding air.Side note, the panel is in an old basement, so the ambient temp was in the 60's.
11-01-2012, 01:35 AM #6
As it is, I am already calling out a long laundry list of other items that need the attention of an electrician. The property is originally 1916 with old barns, shops, tack rooms, pump houses. Lot's of places for Grampa Ned to screw up the wiring.
11-02-2012, 09:08 PM #7
11-02-2012, 09:53 PM #8
No more than 35 degrees above ambient.
11-03-2012, 05:20 AM #9
Ambient temperature rating will depend on breaker manufacture, but the temp should be on the breaker itself.
Without knowing make of breaker, its a guess at the very least.
Temperature Derating for Circuit Breakers
Frequently Asked Questions
