    Myrtle Beach, South Carolina
    Default single ground wire to bundle
    Does anyone see a problem with this?...It's a first for me..
    www.Home2Spec.com
    Default Re: single ground wire to bundle
    Thank you.
    www.Home2Spec.com
    Mar 2009
    Colorado Front Range
    Victor, it can "reasonably" be expected that there is no current on a grounding conductor under normal circumstances. In the event of a fault it can "reasonably" be expected that the fault current will only be on one of the grounding conductors in the bundle that is crimped, so there is no reason why one grounding conductor of the largest present in the crimped bundle couldn't handle the largest expected fault current present in the bundle - and be the connection to the ground buss.
    Apr 2008
    Western Massachusetts
    Still, all that nonsense for want of a $10 grounding bus bar. The shortcuts some people take...
