Results 1 to 3 of 3
12-13-2012, 10:37 AM #1
Tankless WH Receptacle Cover Plate
Exterior wall-mounted tankless water heater. Receptacle cover plate required to be listed and rated for damp area? In-use type?
Similar Threads:Texas Inspector
http://www.texasinspector.com
12-13-2012, 10:15 PM #2
Re: Tankless WH Receptacle Cover Plate
That receptacle outlet is required to be:
- listed and identified as weather-resistant (WR)
- listed and identified as tamper-resistant (TR)
- GFCI protected
- and if that enclosure is not a raintight enclosure, then the receptacle outlet also needs to have a bubble type cover for it (was there a door over that area, or was it open?)
That looks recessed into the wall, is the proper wall insulation R-value in the wall behind it?
That water heater is bottom fed, does it have an atmospheric vacuum breaker installed?
Is that cord rated for that use?
12-14-2012, 09:14 AM #3
This was not intended to be a duplicate thread. The site chose the very moment I pushed the post button to have a little database experience.
Texas Inspector
