    Royce Moore's Avatar
    Royce Moore Guest
    Default No main electrical disconnect located outside!
    I could not find an outside electrical main disconnect breaker today just a meter. I opened the inside panel box and this is what i found! Why would anybody do this?
    Oct 2008
    Tulsa, OK
    Default Re: No main electrical disconnect located outside!
    your pic is very out of focus, but it looks like an FPE panel with a split buss. The top can have 6 throws and that serves as the disconnecting means. There doesn't have to be a main outside unless the locals have modified the codes.
    Aug 2008
    That was done in a factory. I agree that it looks typical of a split bus panel arrangement. A larger view of the panel would help.
    Royce Moore Guest
    Thanks for the info. I understand it now.
