Thread: What is this?
09-25-2007, 04:40 PM #1
09-25-2007, 04:51 PM #2
Re: What is this?
09-25-2007, 04:52 PM #3
Re: What is this?
hey thanks! so is the configuration okay?
09-25-2007, 05:02 PM #4
Re: What is this?
09-25-2007, 05:03 PM #5
Re: What is this?
Jeff,
Looks OK to me.
It either cuts off water flow or boost water pressure.
WHOOPS!!!
09-26-2007, 01:24 PM #6
Re: What is this?
That is a Honeywell motor actuated valve, usually used as a zone valve for hot water heat. The only ones I have ever seen are 24 volts.
09-26-2007, 01:53 PM #7
Re: What is this?
Jeff
If that gypsum partition covering is the fire protection between the units it needs fire taping/sealing. Also, how does one access that electrical J-box?
