03-14-2013, 05:39 PM #1
Main line behind electrical system
Hi everyone,
Is it legal to have the main drain line passing behind the electrical system ?
Thank you for your help !
Similar Threads:Last edited by Christian Tag; 03-14-2013 at 06:18 PM.
03-14-2013, 05:52 PM #2
Re: Main line behind electrical system
I see the old drain line cleanout below the electrical panels. I don't see a shock hazard in those two pics.
03-15-2013, 04:40 AM #3
03-15-2013, 04:52 AM #4
Should be ok. I seen drain line above the panel in newer townhome.
SmartChoice Home And Mold Inspections
Brampton Home Inspections Mississauga Home Inspector Toronto - Home
03-15-2013, 04:09 PM #5
03-15-2013, 05:23 PM #6
[QUOTE=keithsines;222519]Short answer, not usually. Refer to NEC 110.26 (F)(1)(a) through (F)(1)(d), Dedicated Equipment Space. But, are you doing a home inspection or Code Inspection. In this case what you see is what you get unless there is a hazard
Yes there is dedicated equipment space and there is dedicated work space. As others have stated, I would not concern myself if I were a HI unless you see a hazard. There is concern if piping (especially water) is above electrical equipment. A messy wiring job is not necessarly a hazard, but a DIY job. The NM cable hanging down near pipe in pic is a hazard.
I would refer to 'electrician evaluation' just to cover butt, because you just know there is some skeletons in them there closets.
