Thread: Behold, The Mystery Sphere!
05-14-2013, 12:17 PM #1
OK, Oldsters. Anyone have a clue what this things is? House is 124 years old.
05-14-2013, 01:15 PM #2
Re: Behold, The Mystery Sphere!
05-17-2013, 04:23 AM #3
Actually they are not that old and are commonly referred to as "Rate-of-Rise" detectors. They respond to rapid changes of temperature such as caused by a fire just starting out, as well as a fixed temperature. A common way to test them is to just place your hand on the unit. The change of temperature from your hand would set set them off.
05-17-2013, 06:00 AM #4
05-17-2013, 06:31 AM #5
05-17-2013, 11:44 AM #6
And, these older rate-of-rise heat detectors are a major PIA for firefighters since they often false alarm with changes in weather / barometric pressure. Climate change will probably cause them to all go off together sometime in the next two or three thousand years. Better add it to your reports...
05-17-2013, 03:50 PM #7
